just fitted them, but not wired in as i dont fancy taking fuse box out whilst its p'ing down
as seen in the how 2 they are wired up to pin 50 which is for rear screen, but is there any other tips in wiring as i really want to make sure its 100%
hi
yes black wire pin 50
and brown wire earth
done this myself so know it works
Rather wet today so no chance I'm fannying with electrics in this weather
Sorry to pee on your chips pal,but they dont really work in any case,i have them fitted and the damn things still freeze up sorry.
no problem m8
Not a good thing electrics and water mixed![]()
Mine don't work either and they were modified by Vauxhall with new ones a couple of years ago but have never worked always freeze up![]()
You aware you need the rear demister on for them to work arent you? (Thats if your using the standard wiring)
Thats rather you washer bottle that does that... as you probaly dont have enough "alcohol" in it..
heres screen was is able to do minus 21 (but startes to get like slushice at minus 12-14)
so no alcohol, every thing will freez up, not any heated washerjets can help on that.
