need help my heater is blowing look warm air out when on full both pipes are gettin hot and the pipes goin to the matrix one is hot one is cold could it be my thermostat r will ther be an air block has any one got any tips my vectra is 1.8 2004
is your temp gauge moving up to running temp when driving? if not could be the thermostat. had mine done today,
Have you give this a very good run?
Why i ask is the thermostat may open at 92c so when it's -8 it will take longer than it would if -1 to warm up.
I drive 8 miles today to work in the diesel which takes longer anyway and the temp gauge did not move which is normal.
Please don't expect it to work quicker if it's much colder outside.![]()
luke warm not look warm mate
either a blocked matrix or air lock in matrix (if you think about it its a circle the water flows all round system so should be hot going in and hot coming out) try to back flush swap in pipe to out or pour water down the return from engine bay slowly so the air can escape
thanks markj23 just flushed the matrix with hose pipe got heat stright away this has done my head in for ages so simple
