Thread: Power Steering Fail in Cold
    Regular Member MrAnderson's Avatar
    Lisburn
    Default Power Steering Fail in Cold
    Hi everyone,
    Just wanted to gauge some opinions on this before I start spending anymore money at the dealers!
    Over the last while my power steering hasn't been 'activating' properly on startup. It happens every 7th time roughly on starting the car. However with the properly cold mornings it has been happening more regularly.
    If I leave the car to warm up and then turn it off and on, it will re-activate properly but it can take a long time to warm up enough to do this.
    I have been able to drive it ok without the power steering but obviously this is something I need to get sorted.
    Is this something that I could possibly sort myself? I have just spent a fortune on servicing and don't have the money to go back to dealers!
    Do you think it's electrical? (alternator etc) or a failure in the power steering system?
    Thanks in advance for your help.
    Lisburn
    Any thoughts??
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Best to get any codes read and get battery and alternator checked out if its power steering there should be a code.
    Irmscher Insignia CDTI 130
    Lisburn
    Thanks mate, am I right in saying that the codes can be read only while the warning light is on?? Or is there a history of codes stored that can be read?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Major faults will have the code stored I believe.
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Quote Originally Posted by MrAnderson View Post
    Hi everyone,
    Power steering fluid can get very cold and not work as efficently as should do. Give it a mile of constant turning and should ease up.
    scotland
    My 06 Signums' steering has been playing up since the onset of this very cold weather. I thought it had totally failed on one very cold morning it was so stiff and notchy. By lunchtime in the midday sun it was fine
    Obviously temp related but is this really acceptable in a supposedly modern car? I dont think so.
    Throw in the seasonal clonks and binding from the suspension towers I get every year (crud build up?) on this ****** car you can understand why I'm eyeing a Jap car replacement next year. One can only take so much
    jilava
    Check the pressure in your tyres. This has once happened to my father. As the weather gets colder the temperature of the air in the tyre drops and so does the pressure. And if the tyre is deflated it's harder to move by the power steering witch pulls more current, maybe it has a threshold for current. Once at the right pressure power steering was ok on my father's car.
    Central Scotland
    You really need it plugged in mate, run diagnostics on the EHPS. The EHPS is fairly reliable on Vec C's. The VX Meriva's were/are prone to EHPS failure, steering gets hard to turn left or right, if left untreated then it's hard to turn both ways and a new rack is required at £400.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering feels odd when cold!
    By noonaldinho in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2012, 00:02
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. 2.2DTi - Cold start fail at -1°C
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 13:58
https:www.vectra-c.comforumshowthread.php123817-Power-Steering-Fail-in-Cold
vectra c sticky steering when cold
