Results 1 to 10 of 13
Thread: Tyre pressure
    Regular Member Happy Girl's Avatar
    Never enough Costa!
    Vehicle : Coupe
    Trim : SE
    Engine : 2.L
    Year : 55
    Question Tyre pressure
    In this freezing cold weather does tyre pressure make a difference?
    Need to make any adjustment or just put in what you normal would do?
    Oooops put in wrong section
    Regular Member carlsondavid33's Avatar
    Aug 2010
    wirral
    i keep my snowies 42 at front and 38 rear
    Regular Member Ademusic's Avatar
    Dunstable
    I've lowered mine a tad, and it seems okay, but heard it doesn't make much difference and people say to keep it the same. As long as you check it on a regular basis and it's as it should then it should be fine, I believe the pressure changes slightly with the temperature though sure someone can give more info on this
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Same as normal. I never change mine.
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    I'd keep them inflated like normal. If it gets really bad you could lower the pressure in the tyres right down to get you out of a sticky situation depending on which wheels you have. I did this in my Corsa last year, just blew them up again with one of those 12 volt cigarette lighter air compressors straight after.
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Ademusic View Post
    Correct, the hotter the tyre the more pressurised the air inside is. That's why you're supposed to check your tyre pressure when they're cold.
    Aug 2010
    wirral
    johns also a 42 front 38 rear kinda guy lol
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Quote Originally Posted by carlsondavid33 View Post
    Same as mine, mate.
    BTW, How do you find your's handles with the extra pressure?
    EDIT: Just seen your last post. You must be telepathic. LOL
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I keep mine normal - especially with low profiles. I would say its dangerous no matter what to have incorrectly inflated tyres.
    Gazza4
    Aug 2010
    wirral
    yes john mate seems to handle alot better but then again when i checked i was running bout 25ish each corner lol, regular checks now tho
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
