In this freezing cold weather does tyre pressure make a difference?
Need to make any adjustment or just put in what you normal would do?
Oooops put in wrong section
i keep my snowies 42 at front and 38 rear
I've lowered mine a tad, and it seems okay, but heard it doesn't make much difference and people say to keep it the same. As long as you check it on a regular basis and it's as it should then it should be fine, I believe the pressure changes slightly with the temperature though sure someone can give more info on this
Same as normal. I never change mine.
I'd keep them inflated like normal. If it gets really bad you could lower the pressure in the tyres right down to get you out of a sticky situation depending on which wheels you have. I did this in my Corsa last year, just blew them up again with one of those 12 volt cigarette lighter air compressors straight after.
johns also a 42 front 38 rear kinda guy lol
I keep mine normal - especially with low profiles. I would say its dangerous no matter what to have incorrectly inflated tyres.
Gazza4
yes john mate seems to handle alot better but then again when i checked i was running bout 25ish each corner lol, regular checks now tho
