Just read this on another forum & thought some of you guys may like to check it out...............
After investigating due to hearing about HID conversions becoming llegal I found the following changes will take effect from December 2011
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers.
Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug).
Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure.
Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure.
The above was confirmed in the October 2010 VOSA newsletter. Which can be viewed as a PDF from their website. Link below, see page 8 for details.
http://www.dft.gov.uk/vosa/repositor...Oct%202010.pdf
The specifics of the chipped ECU seem to imply that it will be tuning boxes that will fall foul as it would be hugely impractical to check for an ECU rewrite, the following has been attributed to GHE Tuning and John Robins.@ DNA Tuning:
