Thread: help, looking at a zaf 1.9 120
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default help, looking at a zaf 1.9 120
    Not long ago got an astra but swmbo is wanting a bigger car again for family journeysis there anything I should be looking out for on the 120 engine? I know absolutley zero about oil burners.......thanks guys
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    The 120 is the more reliable engine IMHO. Listen for a DMF rattle by depressing the clutch slightly. Should have good acceleration above 2000 rpm. (egr check) Not much really to check....
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    is it an audible rattle or vibration when the clutch is depressed m8? thanks
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : Astra j sports tourer
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    the 120ps engine is very reliable,you shouldn have many issues with the
    120
    i had a vectra 120ps and was very reliable and would have another
    anytime.
    Jun 2007
    in a white box
    Quote Originally Posted by Morephun View Post
    never had one but lots of threads on here about it. I believe, if you have it, you will know.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    I had a zafira cdti 120 auto. It was a good car. Its very modern actual. If you choose a manual box its the dual mass flywheel who has been the big problem. But you will find out if its ok or not when you drive this car. If broken it vibrations and noisy.
    The autobox have not this big problem because its a more adaptive conection to the gearbox. Auto box is a good gearbox and it tolerate tuning very good (max torque 450 nm)
    The 120 engine has the normal egr-problems, but its easy to fix. Dpf can also be little difficult have I hear.
    I removed dpf from my car and got a remap. 1,55 bar boost pressure and litle extra diesel and it was a very quick car. Its good to drive and children like this car
    Mine was only two seat, because the big taxes in Norway.
