Thread: Alternative tyre sizes
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default Alternative tyre sizes
    is it right that 215/50 17 is an odd size and that is why they are expensive ?
    i am sure i have read that there is another size i could use without any tech 2 alterations. can any one tell me this size please ? and the price difference between the two. cheers
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    iirc the alternative size is 225/45 R17, with regard to the price difference its hard to say as with anything if you shop around you shall find a bargain. I bought my tyres off here http://ssl.delti.com/mytires/start.html Remember though keep the speed index and load rating the same as your originals just to ensure you have no problems with your insurers should the worst happen
    HTH
    Apr 2006
    Leicester
    thanks for the response and advice. cheers mate
    Try this site too for a tyre size calculator
    http://www.miata.net/garage/tirecalcold.html
    I had 225/45`s on the vec, they were spot on, and from behind looked much better as they filled the arch out a bit more ...
    Another couple of links as well for good measure ..
    www.mytyres.co.uk very cheap ..
    www.blackcircles.com cheap as well ...
    Regular Member JYsV6's Avatar
    Dec 2005
    CUMBRIA
    I've just had 225/45/17's fitted today. Will I need different tyre pressures from those recommended for 215's?
  1. different tyre sizes
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2016, 17:44
  2. Tyre sizes ?
    By MAF 3.2 V6 GSi in forum Suspension, Wheels & Brakes
    Last Post: 18th September 2010, 22:25
  3. tyre sizes
    By mrpatterson2008 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 17:50
  4. alternative tyre sizes - again....
    By nickc in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2008, 02:10
  5. Alternative tyre size to 215/50/17
    Last Post: 9th May 2008, 18:45
