Results 1 to 10 of 17
Thread: Snow Button on Auto Box
    Cheshire
    Default Snow Button on Auto Box
    Hi All,
    Anybody know if i can use this for the whole of my journey i.e. 30 miles to work? or is it meant to be turned off once out of the thick snow and you are moving?
    Might sound like a daft question but want to make sure im not doing any damage to the box!
    SCOTLAND
    That is a very good question actually, i had mine on for a fair bit of my journey and never thought about it.
    Jun 2006
    Kirkintilloch, Scotland
    Quote Originally Posted by Morzy View Post
    Hi All,
    I have the same question but would also like to know what it actually does.
    I thought it would simply stop the vehicle engaging the lowest gear but this morning it seemed (my imagination perhaps?) to prevent wheel spin when I put my foot hard on the throttle.
    Dave
    13 Post(s)
    Quote Originally Posted by DaveG View Post
    It forces the gearbox to use forth gear from start off.
    To answer the other question, if used, I tend to switch it off once moving. In the 14 years I've driven an auto though, I've probably only used it 3 times in anger. The only other time I've used it is to test it still does what it's meant to do.
    To quote from the handbook though - "To protect against damage, the starting off aid automatically cuts out at very high transmission oil temperatures."
    That would seem to suggest that no damage will occur if you left it switched on as it has its own built in self preservation mechanism to switch itself off anyway. For safety's sake though if you were on a good non slip surface and you needed to make a quick getaway (say from a busy junction) you'll find you won't be able to and could end up a sitting duck in front of the artic you just pulled out in front of.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I just had words with the Dealer on this, he asked how I was getting on with it, I'd forgotten I had it. He described it as a "winter gearbox" and led me to believe it somehow altered the ratio's, like the sport button in reverse. Also said it pulls away in next highest gear, which would be second. Would think for most circumstanced fourth would be a bit much. However, my son managed to put a Renault Megane down a steep hil, through a fence yesterday, coming off his driveway, not sure what gear he was in lol
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    OK, just had a look at my handbook. It seems Vx are confused, page 172 says using the "snowflake" button sets the car off (in auto only, not manual mode).
    It also refers to page 180, where it states press the snowflake button and the car shifts to 4th gear.....will the real Winter programme please stand up
    Oct 2010
    London
    I know what it does peoples - press the snowflake and the box will set you off in 3rd gear effectively locking out 1/2.
    Definately turn off once on solid ground though, imagine trying to pull away in a hurry in 3rd gear!
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    The non-GSi vectras over here have the snow button instead of TC off.
    Drove my mates with it on and yes, it just engages a very high gear so as to not spin the wheels. Basically limp mode. Pointless over here.
    Regular Member wardy's Avatar
    Chichester
    whether it starts you off in 3rd or 4th may depend on which box you have. On the 6 speed auto in the vxr it starts you off in 4th not 3rd. That is all it does & thereby prevents wheel spin. It is also true that it only works with the auto (D) mode not with sequential manual shift.
    Does the Vectra even get a snow button on Manual? And was there a sequential box?
  1. snow flake button
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 22:29
  2. Auto Button on Climate Control Not Illuminated
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 19:02
  3. Auto button next to fan control (bulb)
    By petrolhead55 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 23:17
  4. Sport Button - Auto CDTI - Did you know!!!?
    By mushy2007 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2008, 00:59
https:www.vectra-c.comforumshowthread.php123741-Snow-Button-on-Auto-Box
https:www.vectra-c.comforumshowthread.php123741-Snow-Button-on-Auto-Boxpage2
