Results 1 to 2 of 2
Thread: engine coolant/temp gauge/heater
    Sep 2010
    WIRRAL
    Default engine coolant/temp gauge/heater
    2003 vectra 1.8sri 16v.........advice needed please
    enginee coolant now needs topping up every other day, level drops 1 inch or so every time. up until a week ago topup maybe 1 every 2 months
    mechanic has checked this several times, gas test on engine....dye in the header tank not leaking! he suggested the only other thing could be the head gasket (gulp) but its running sweetly so dont want to spend £500 if not required!
    not sure if relveant but i'll mention it anyway temp gauge doesnt move from its lowest level (hasnt done for months), had new resistor fitted 2 weeks ago as heated only work on 4, last few days only warm air blwing out
    anybody else had similar problems, if so is there an easy fix!
    thanks in advance
    mick
    Sep 2010
    WIRRAL
    forgot to mention........i have been using normal tap water to top up, is this OK
  1. Engine Temp Gauge not quite right
    By Di frost in forum Engine & Drivetrain
    Last Post: 30th December 2011, 12:52
  2. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
  3. engine coolant/temp gauge/heater
    By redmoog in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:27
  4. coolant temp gauge
    By KeefyB in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 12:10
  5. Temp Gauge An Heater Probs Any Ideas
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2008, 23:30
