Thread: ABS Light On???
    Regular Member kamar's Avatar
    bradford
    Default ABS Light On???
    hi guys... got loads of snow in bradford... so did many other parts i would guess..
    car got on well till at one point i kicked the brakes hard thanks to a pedestrian...
    now the abs light is on.. any ideas or sugestions...
    cheers
    It probably didn't like the snow/ice. Is it still on after a restart?
    May 2008
    Greenhithe, Kent
    Hi Kamar,
    I've has Carltons and Omega's and a Vec C elegance all do that.
    I think the ABS will re-set itself and the light will go out when you restart the car. Unless you have already tried that option.
    If one wheel spools up "or down" faster than the other and the system is unable to correct it then a fault code - light will come up.
    But on restarting it will do a check and if all is OK will re-set.
    So see how it is tomorrow.
    In this weather anything can happen.
    Colin
    bradford
    cheers guys... ive started the car up and its still on. lets see how it is in the morning.. its just that they never came on on my 2 vec b dti's and my vec c i had before.. oh well.. thanks guys godd luck in the snow..
    Someone on here had it last year iirc. Turned out to be the abs signal gear thingy full of snow and ice. When it melted it was ok.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Mine came on the other day in the snow,and stayed on,and came on and stayed on,on the next start up,but it soon went out after going for a drive.
    Regular Member 111's Avatar
    Stockton-on-Tees
    I sat outside the house with the wheels spinning for about 2 mins trying to build up some heat to melt the snow when my light came on, it went off after a short run.
    bradford
    sorted mine went off 2day after driving around 5 metres from home...
    Regular Member mccluskey119's Avatar
    gourock
    Mine came on the other day and hasn't went off in ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by mccluskey119 View Post
    How many miles have you driven since it came on? As I understand it the ABS systems needs a bit of time and distance to work out whether there is a genuine fault or if it's just a one off - ie snow etc.
    Gazza4
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
