Results 1 to 10 of 27
Thread: traction control in snow
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default traction control in snow
    tried to get to work at 5 this morning,8 miles later turned round back home ,the t/c control just killed the revs ,the light flashed on and off,and the car crept up a fairly steep hill at walking pace. is this how the t/c usually works
    as i've not had t/c before
    thanks
    Regular Member rockhopper's Avatar
    Scotland
    Yes because revs is the last thing you want in snow but the t/c doesn't manage in snow very well. Best thing to do is turn the t/c off and control the wheel slip yourself.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by rockhopper View Post
    This. I turn it off in mine on the snow. We got some last night so went out to see how the car did, it really can't understand snow properly. Turned it off and controlled it myself.
    durham
    Trim : Leather
    Yep what rockhopper said, it's useless In This weather IMHO turn it off or you'll never make it up that hill!!
    West
    As already said TC is a waste of time in this weather, if you can turn it off then do so
    Trim : improving
    Year : 06
    06 cdti button fitted not working, i'm told it is impossible to switch off
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Depends what model you have. Most pre facelifts you can buy the switch and it will turn it off. Mine works.
    Regular Member 111's Avatar
    Stockton-on-Tees
    My T/C doesnt work so I'm o.k, I would rather it this way than not been able to turn it off. 2007 2.0t signum. 1st time I have ever been pleased that something is broken.
    preston
    i have a 55 plate facelift.
    didn't even know it had t/c until last winter
    started in 2nd to prevent wheelspin then going up hill tried to give some revs to gain a bit of speed, revs just died back the minute t/c kicked in as front wheels started to loose grip.
    progress was very slow....but safe i guess
    ah well
    I don't have a switch for it , so bearing this in mind, how easy is it to fit a switch to facelift? then i can turn it off as and when i need to get up a steep hill
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Quote Originally Posted by mparks8590 View Post
    ah well
    you can first ck to see if you have a connector block behind the blank switch ...purchase a t/c switch from VX ...but it still might not work ...but will just light up when your lights are on ..
    there have been mMASSIVE of threads about this ....some work some dont ..even with the block there .
  1. My Vectra and traction control in the snow
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 10:14
  2. poor traction in the snow.
    By kdadidog in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 00:17
  3. Traction Control and/or 4x4 (snow/ice)
    By Birchy63 in forum The 'Off Topic' room
    Last Post: 21st December 2009, 15:10
  4. Traction Control in Snow
    By Ridgerider in forum Engine & Drivetrain
    Last Post: 13th February 2007, 14:54
  5. Traction Control
    By swalk999 in forum Handling & Braking
    Last Post: 22nd January 2007, 23:05
