Results 1 to 10 of 22
Thread: need help if possible please
    Nov 2010
    bracknell
    Default need help if possible please
    Hi Firstly great forums, I am now a proud owner of a 2003 signum! and must say love the car.
    The problem
    I purchased the car today cheap BUT
    6 gear there is no drive , slight whine but just revs, gears 1-5 flawless and very smooth.
    car has done 82k full service history (all VX apart from last)
    Could i complain to them? as it seems quite odd
    any ideas? also if its stripped the cog is there a magnet at the bottom to hold the pieces? as it still drives lovely and smooth but no 6th gear!
    thanks in advance
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    what engine is in the car?
    It will probably be easier to buy a secondhand gearbox and have it fitted but will probably cost about 500 quid all in..
    Nov 2010
    bracknell
    hi mate its the 2.0T
    do you think its ok to still drive? as it still drives lovely, no noises jerking or anything would vx cover this? even though its done 82k? as surely the drive should not go in 6th only
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    you are out of warranty so vx will not cover it, and they will charge you a fortune, did you buy it from vx or a dealer?... the labour charges involved in taking off a gearbox and then taking it apart bit by bit etc will cost more than replacing it with a secondhand unit. If they were able to see damaged parts inisde the gearbox getting the parts will be expensive or be secondhand..
    I would not like to say whether its ok to keep driving it, the F40 gearbox is a good one, it can be a bit clunky but can take a right beating. I am not familiar with anybody else having this problem with that gearbox.
    You may want to drain your gearbox oil to see what it looks like then refill it will 2.4 litre of fully synthetic..
    Nov 2010
    inverness
    Gear linkage cable?
    Nov 2010
    bracknell
    Quote Originally Posted by total_vxl View Post
    Gear linkage cable?
    it seems to go into the gear fine but whines alittle and goes nowhere and just revs, all other gears are ok could this be a linkage problem???
    thanks
    thanks caveman for the advice
    Nov 2010
    bracknell
    its strange as its only effecting 6th gear no other gears are effected they pull and sound fine. No hassles in changing its very smooth no clunking or anything
    Jul 2009
    The Rift, Cardiff
    Did you buy it privately or from a dealers/garage?
    Nov 2010
    bracknell
    privately , i got a good deal on it as its got 1yr mot and 2 months tax and still drives fine
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    you always want to try the cheapest option, but as you that you can actually select 6th but nothing happens other than a whirring sound is puzzling. Hopefully somebody who will come along and chip in with some better info but you do need to get it diagnosed as you do not want to loose any more gears.. I spend a lot of time in 6th and my car will still take off in 6th when i put my foot down.. I have the same engine and gearbox as you btw.. you will get better mpg using your 6th so its gotta be worth getting it diagnosed somewhere, you could try your local vx dealer, just ask for diagnosis and then get the work done elsewhere..
