Results 1 to 10 of 11
Thread: Fog Light upgrade bulbs ?
    Symington (Biggar)
    Default Fog Light upgrade bulbs ?
    Hi guys can anyone advise on a good foglight H3 bulb to match up with HID 50W 6K main beam. Have put Nightbreaker plus in full beam which are a bit yellow. Also anyone in my area recommend someone to repair the adjusters as one has come off and does not allow any adjustment, my fault trying to get more light on the road and it popped off. Any help or point in the direction of a decent garage who will fix it
    Oct 2007
    Shropshire
    You won't need the fogs now you have Xenons. Xenon light does not reflect back as much and you will find dip beam just as good or better than the fogs....
    13 Post(s)
    Maybe he just wants to look cool instead of using the fogs for their intended purpose?
    No idea why the OP has fitted HID lighting to his main beams though. Far better to have fitted them for dipped beam use because of the delay in getting them to light up and it can shorten their life by continual switching on and off.
    Regular Member fingers66's Avatar
    Carpe Diem
    I think he means main beam as in dipped beam as he states he has fitted Nightbreaker plus in full beam.
    13 Post(s)
    Ah!
    Main beam and full beam mean the same thing to me.
    Symington (Biggar)
    sorry meant dipped for HIDS, not interested in looking cool, you would realise if you saw me, just looking for decent performing lights. My lights are nice and bright but pointing in crazy directions RH full beam crosses the LH side and points up in to the sky and doesn't hit the road at all, I really need then adjusted badly, local village garage has look at them twice and say they are not adjustable thats the way they are supposed to be they also can't fix the LH dip which has come off the adjuster as it doesn't move at all when you turn the allen key in the yellow thingy. Advise help anyone,, really frustrated that I've got these cracking lights and can still see zip
    mumbles
    hi mate
    i have got 50w 10k hid in the headlights and 50w 10k hid in the fogs
    i do alot of driving in country lanes and the fogs make a big difference
    also they dont seem to bother oncoming drivers either.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    M-tecs should do the job.
    13 Post(s)
    Quote Originally Posted by 37kram View Post
    They might bother those drivers with blue lights on the roof. I think it's something like a £40 or £60 fixed penalty fine for causing undue dazzle.
    Oct 2007
    Liverpool
    Michaelangelo, Did you have any luck sorting out your main beam aiming ? My Dip Beams are great with Orsam Nightbreaker Bulbs but like yours my Offside High Beam Crosses over to the left and leaves the offside of the road un-illuminated.
    I have tried to Adjust my fog lights after discovering that the are only just illuminating the area immediately in front of the bonnet ! (Typical first time we have fog and the fog lights were useless !) But the adjusting screws just turn without any change in the fog light aim is this just the screw becoming disengaged from a captive nut or is it going to more than this ?
  1. Best White and Bright upgrade headlight bulbs
    By Mikeymate in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 16:03
  2. Recommend me some upgrade headlight bulbs
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 16:48
  3. what headlight bulbs for upgrade?
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 22nd August 2009, 16:55
  4. How to upgrade headlight bulbs (Facelift)
    By BRYBURN in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2008, 16:51
  5. Headlight Bulbs - Upgrade
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 19:37
