Thread: Vectra C Facelift, faulty front fog lights glass
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default Vectra C Facelift, faulty front fog lights glass
    Hi Guys, i have a 2008 vectra SRI CDTI 150 Hatchback. During this cold weather and snow i put the fog lights on once, then i checkd today and noticed that on of them is cracked!!
    I know i have not hit anything.
    Whwn i used to work at vauxhall im sure they said this is a fault on these vectras, is that correct?
    Would this be covered by the manufacturer? warranty has expired. cheers mike
    Dunstable
    Not a common problem as far as I'm aware, you may have had a stone hit it and crack it. Only way to fix is to replace the whole foglight as the glass is bonded on and can't be replaced. Best bet is to check on ebay for a spare.
    Sep 2010
    Lincs
    Ok thanks, i just remember at vauxhall, when there was cold weather all the sales cars that were being used always had cracked fog lights and the guys said it was a fault on them vectras. It looks like an internal crack as there is not ridge when i run my nail over the cracked area and there is no sign of a chip or damaged , just a clear crack from top to bottom.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    No I have the same problem Apparently the Astra's have a common fault with their fog light glass cracking.. cant remember if its a recall though. I have wondered if its the same part? Do you have the round fogs with the chrome rings also?
    Bordon, Hampshire
    Quote Originally Posted by 150_SRI View Post
    And yup its definately internal as I had condensation on the inside before hand too
    Sep 2010
    Lincs
    Ok... Nah i just have the standard SRI Fogs on the facelift. think its only the signums that have the chrome surround and the vxr vectra. Its a bit crap that they crack as i imagine they are not cheap to replace?
    How much do you think the part will be and the labour time to do the job?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    I was quoted over £100 each (iirc), from vauxhall. Found them on eBay for around £50 each. It's easier to remove the bumper to fit, so budget for 2 hours labour.
    WGAF#5
    the problem is owing to the build up of condensation in the lamp unit sometimes its a quantity of water present that then when it freezes expands and cracks the lamp unit .... although its a design flaw you wont get it under warranty which is a sad state of affairs ...
    they did release a modified snorkle type kit to help remove the moisture and condensation and it should be standard on the facelifts and later pre faces ......but you still see condensation present on these as well so it makes you wonder
    Sep 2010
    Lincs
    Ok thanks for the reply. Thats the odd thing though, the fog lights were immaculate, with no condensation or water in them at all. Never seen them with condensation in either.
    I dont want to see the fog light cracked but then again doesnt seem any point in replacing it as will prob just crack again, vicious circle!!
    13 Post(s)
    No sign of a snorkel kit fitted to my facelift.
    I bag of dessicant (moisture absorber) stopped my from condensating up.
  1. Genuine Vauxhall pre-facelift Xenon front lights
    By merikiito in forum Parts for sale
    Last Post: 18th April 2010, 16:13
  2. Facelift SRi front Fog Lights - Pair
    By Phil MC in forum Parts for sale
    Last Post: 3rd May 2009, 21:34
  3. Sri Pre Facelift Front Lights
    By Bethan39 in forum Parts for sale
    Last Post: 23rd November 2008, 10:39
  4. Front lights on facelift
    By Davexctra in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2007, 19:20
What fog lights for vectra c faclift
where can i buy glass for fog lights vectra c 2008
