Results 1 to 10 of 16
Thread: Dti Glowplugs
    Regular Member Dazzy2006's Avatar
    Notts
    Default Dti Glowplugs
    Well looks like its my turn to need glowplugs
    Has anyone changed glowplugs on a 2.2dti - whats the best way of getting at them - i took a look earlier and was wondering the best way of changing the 2 near the turbo
    Also what brand do you guys recommend? ngk etc or just pick some up from local auto factors.
    The main thing i'm worried about is snapping one of so my plan is to spray wd40 on them for a couple of days, then try removing them when the engine is warm and when i fit the new ones copper grease the threads - any hints/tips appreciated.
    Cheers guys
    Notts
    - anyone?
    Bristol
    Vehicle : CDTI 150
    The Vx ones are Bosch.
    Vx retail the glow plugs at £12.30 each which isn't to bad.
    If you go to Eurocarparts on line they list a Denso glow plug at £13.81....
    Whilst WD 40 is better than nothing, try using Plusgas. Its a penetrating oil whilst WD40 is designed as a water dispersant hence WD.
    Warm engine is better for removal.
    Main thing - ensure you only apply a rotational force to the socket not a lateral one.
    Good luck
    East Midlands
    Use a deep 10mm socket mate,and the two near the Turbo are best removed using a universal type joint adapter,just be a bit cautious and take your time and you should be ok oh and wd 40 fine to aid removal.
    Jul 2010
    Warrington / Liverpool
    Maybe a stupid question but how do you know they need replacing, only reason I ask is that my 2.2dti is struggling to turn over in this ridiculous weather... Do you get any warning lights?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by UncleMelon View Post
    I don't think you get a warning light unless one dies completely and ruins the continuity of the circuit. I think it's pretty much by feel, as far as I know they do wear out. If they take ages to heat up and the car is difficult to start, they may need replacing.
    Bristol
    Vehicle : CDTI 150
    I suspect your problem may be due to either battery on the way, starter motor and would check connections to ensure clean and tight.
    Glow plugs just heat the cylinder to assist the diesel burn whilst the engine is cold. So glow plug fault shows with a longer, but at same speed, crank and what sounds/feels like a misfire for a few seconds as the 'cold' cylinder heats up.
    Therefore struggling to turn over is more likely to be as previously mentioned.
    You can check battery with a voltmeter, best to check first thing anything below 12.5v at this time of year is not good and realistically even the best batteries with the latest electrolytes are only warranted for 5 years. So whilst some batteries soldier on anythin with the older 'technology' thats over 6 years old is doing well.
    Jul 2010
    Nice one for the replies cont1204 & lesj,
    From the way you've described a crap glowplug i think that may be my problem...
    Its not really like there isnt enough power to turn it over its just taking a few more turns than normal, and i can definately feel what seems to be a very slight misfire after starting from cold. not for long though and its not really something i considered to be a problem until it was mentioned.
    Should there be an indication when the glowplugs are heating up properly?
    Cheers fellas
    Edit: I have checked the battery with a battery and alternator tester and its indicating they're both strong... might aswell check it properly with a multimeter though I s'pose
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Cheers fellas
    No worries. If you've had it checked out and it all points to them being fine I'd go for new glow plugs. Mine coughs and splutters a little bit when it's started but after a few seconds it's cleared and it's fine. Has been de-catted though. Which I do recommend.
    Notts
    Cheers for all the replies guys - ive decided i'm going to leave it a few days as the car is buried under the snow
    Mine turns over fine but takes a couple of extra cranks to start but once started i have the car and spanner symbol for about 30secs then its fine till the next cold start
  1. Where are the Glowplugs on 1.9 120
    By Marky in forum Engine & Drivetrain
    Last Post: 23rd November 2022, 20:20
  2. glowplugs threaded
    By alphabravo in forum Engine & Drivetrain
    Last Post: 27th February 2011, 06:54
  3. Maybe more then Glowplugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 24th November 2010, 15:37
  4. Glowplugs snapping
    By Gayno in forum Engine & Drivetrain
    Last Post: 23rd October 2010, 17:28
  5. glowplugs
    Last Post: 23rd December 2009, 10:36
