Thread: Condensation and Water....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Unhappy Condensation and Water....
    Well I had noticed that the windscreen is developing condensation unless I turn the heater up - which eases the problem. Having read a thread on here I will be going and getting a new pollen filter at some point. The aircon works fine too.
    The other thing I have noticed is water in the spare wheel well. I have had a look at the seals on the tailgate after the car has been soaked with rain- and found nothing. I actually think the two are unrelated ie have developed at different times.
    Is there a common part which lets water in?
    Thanks for any help guys.
    Gazza4
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Anyone?
    WGAF#5
    it could just be a build up of water accumulated in the spare wheel well from where you open the boot and the water runs into the seals and then down into the boot - all you can do is dry out the car as best as possible and then try again ... as you seem to have found its a vicious circle with condensation as you dry it out and leave the car ...then it cools down and the circle starts again
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers dez, I gave the skuttle a check and the drain is perfectly clear too. Will keep drying it out.
    I've also been informed that the aerial is a source too but I can't see anything unusual regarding possible leaks there.
    Gazza4
  1. Water, condensation or misted Fog Lights (Foglight)
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 09:46
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. Boot well water/ Condensation
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 22:27
  4. condensation in oil
    By Sir-Signum in forum Engine & Drivetrain
    Last Post: 22nd March 2009, 12:14
  5. Condensation
    By vecest in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2007, 19:05
