Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: **urgent help req'd!**
  1. #11
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    I had same issue with my wifes car. Heater matrix had completely frozen up so off it went to the garage. They kept it indoors over night, drained the system then bleeded it for air etc, nice and toasty now!
    I think the anti-freeze it was supposed to have in it at its previous service got forgot about or wasn't diluted correctly.
  2. #12
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I would give three options..
    1) Insufficient coolant in the circuit... will blow cool air even when the engine is warm.
    Check the header tank level
    2) Blocked heater matrix - not allowing sufficient flow of warm water - you would need to flush the matrix through with clean water, and then refill the cooling circuit with fresh coolant at the correct mix ratio.
    3) Air lock in the cooling circuit - you would need to firmly massage the large hoses from the radiater to push air though the circuit, until it is expelled through the header tank.
    On an outside chance, the water pump may have become defective - not common, but the impeller blades may become detatched from the cam-belt driven spindle. This would cause lack of sufficient coolant flow through the circuit.
  3. #13
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    ...ok, I have got to the heater matrix and the pipes going to it are both hot/warm, therefore it must be a blocked matrix?....
    should the matrix itself get really hot? thanks..
  4. #14
    Vehicle : Jaguar XF 2.2 Sport LE
    Trim : leather
    Engine : 2.2 d
    If both the inlet and outlet pipes on the matrix feel about the same temp and the body of the matrix is "hot" its possible that the air blend flap in the heater box is out of adjustment or the mechanical control for the flap has come off. Just a thought.
  5. #15
    Jul 2009
    The Rift, Cardiff
    I've got the same on my 1.8 after changing the thermostat last week. Both pipes to the matrix are warm but the other pipes are too hot to hold. I'm guessing blocked matrix.
  1. Photshop req'd please
    By blues n twos in forum Insignia car chat
    Last Post: 13th March 2011, 10:32
  2. Urgent help req'd! Gearbox gasket!
    Last Post: 5th February 2011, 15:06
  3. help req'd
    By chrissri82 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 21:54
  4. urgent help req'd!!
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2008, 12:10
  5. Info req'd
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 12:35
