Originally Posted by
Fireyfella
Thanks for the reply John,
I had a 2003 SRI a couple of years back and the N/S spring went on that, I found out by the knocking & banging every time I hit a pot hole or bump etc. After inspecting, it was loose in the mount and easy to see so I could easily identify the problem. I know they are prone to going however, this one on my 2006 does not make any noise when I hit bumps/holes etc and I could not see anything when looking under and it was also solid in the mounting after giving it a good rive.
I thought I would replace the shockers and springs if the price is reasonable, I got the shocks from LMF at £31.95 each which was the best price I found but that’s where I was told I could only get genuine replacement springs at a cost of £90.00 EACH or a full set of Eibach at £153.00 .
I have phoned round a couple of Motor Factors and they all asked if it was the ‘Sports, Lowered’ spring so I guess this should be fine for the standard SRI and they were £45.00 Each, is this a reasonable price?
