Thread: fuel pipe split.....cdti
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    Default fuel pipe split.....cdti
    just had my rubber hose fuel pipe that sits at the top/back of the engine bay split, has anyone ever replaced this pipe ???? easy job ???? i know it just clips out of the top of the filter but where do's it unclip/comeoff from the other end ???
    pics if possable
    thanks mark
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Mark
    it runs under the bulkhead to a quick release coupling under the car floor pan,there are a few clips to unbolt on the bulkhead,
    you also have to uncouple solenoid valve bracket from air cleaner housing,and wiring harness from plug from mass air flow meter.REMEMBER FUEL ESCAPES.
    Jan 2008
    manchester
    cheers jonny b...........are the dear to buy ?????
    Jan 2008
    llanddewi
    I had the same problem earlier this year, two pin hole leaks made a mess .
    Got a lenght diesel fuel hose of correct bore then cut off the steel collers holding the original rubber hose to the plastic tubes then fitted new hose with double jubilee clips each end (overkill).
    Works fine no more leaks and the replacement hose is thick wall so will bend without kinking.
    Brian
    Oct 2016
    Greenock
    Trim : sri
    Engine : 1.9 cdti 8v
    Default what size of fuel hose
    Quote Originally Posted by llanddewi View Post
    Brian
    Hi Brian, what size of fuel hose did u order? ( internal bore size) currently have same issue with vectra c 1.9 cdti 8v, just wanting to do what you have done. Thanks in advance
  1. cdti fuel feed pipe
    By ronnie63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2012, 14:50
  2. 1.9 cdti sri Fuel pipe size?
    By carlvalley in forum Diesel Engine related
    Last Post: 5th October 2011, 00:21
  3. Split pipe
    By LeeU in forum Diesel Engine related
    Last Post: 10th September 2011, 20:38
  4. split pipe
    By pacman696 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 21:04
  5. help cdti fuel pipe popping out .......
    By wirrallad in forum Engine & Drivetrain
    Last Post: 20th March 2011, 00:02
https:www.vectra-c.comforumshowthread.php123655-fuel-pipe-split-cdti
vectra c 1.9cdti fuel pipe to filter
vectra c engine fuel pipe splithow to replace a fuel line on vectrafuel pipe splitfuel pipecdti fuel pipehow to replace fuel pipe on vauxhall vectraHow long is fuel pipe for a vectrasplit in pipe that runs from fuel to enginevauxhall vectra 02 fuel pipewhat happens if a feul pipe splitscdti splitting fuel pipesvetra c fuel leak pipe diameter
