Can anyone access the Astra EPC? I need a part number for the wife's car please![]()
what part is it your after sir
There's no Astra EPC - there's Vx EPC with all the models on it lol
think thats wot he means lol
ive got epc and i await a reply to wot part he requires
Thank you good people.
I need to know if you can but the plastic collar that seems to secure the door loom into the rear door as mine lets the plug come out and either the door won't lock, or in my current case unlock. I think the collar is worn and hence the plug just pulls out too easily as the loom itself is very short when the door is fully opened by my daughter.
Jezzy reason for asking I have both the BMW and Saab 9-5 EPC's and they are model specific so thought Astra might be same,,,
you cant get the collar seperately unfortinately,i have a few rear door
harnesses from a vectra c so i see if the collars are on them and im sure
there the same as the astra h.
failing that then the collars you have shud hold the plug in place,silly
question but are you fitting it correctly as push the collar in then push the
plug in and as youve got the plug fully pushed in hold it there then at same
time pull the collar back uot then let go of the plug,they can be very tricky
try that then let me know
Andy thanks I will give your technique a try in out in out then shake it all about![]()
