Thread: abs light!
    Regular Member scottyd's Avatar
    paisley
    Default abs light!
    been up to visit my mum with my 12 week old kid, anyway had bad bit of wheel spin in the snow and now my abs light is staying on, hope it goes off after leaving car for an hour or so! at least it should be fixed under warranty along with my thermostat!! car just doesnt heat up only reaches about 50 degrees!
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    It does reset after awhile, mine does this every winter ha ha.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Quote Originally Posted by shadyone View Post
    mne done it last year, before it came on i had alot of wheel spin and TC kept kicking in then i noticed the ABS & TC light were on, it never when out even tho i turned the engine off and back on i drove back home left it over night and it was sorted, i put it down to the snow it must of covered the sensors when wheel spinning
    May 2006
    Mansfield
    Check the connectors from the wheel/hub sensors, I got this once when driving through heavy rain, found that water had got into the connector, dried it out and added a squirt of switch cleaner (NOT WD40). No problems since.
    Hope this helps
    SJ
    paisley
    all good reset ok now!
    Oct 2010
    hull
    nice one
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
