Results 1 to 2 of 2
Thread: clutch problem
    Nov 2010
    Default clutch problem
    Hi, Sometimes when I press the clutch pedal it goes half way down before I feel any pressure. Today it went all the way to the floor. I had to pull it back up, pump it again and it worked.
    I have a feeling the slave cylinder needs bleeding or replacing. Where abouts is it and does it have a separate reservoir or does it share with brake fluid.
    Mike
    Oct 2010
    hull
    have you rebled them? sounds like air trapped somewhere
  1. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
