Thread: 2.2 Direct Major engine fault!!
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Default 2.2 Direct Major engine fault!!
    The other day my car was being driven along normally anyway at a set of light it started misfiring on Cylinder 2 turned it off for around 1 hour and started it back up all was fine but still had the engine management light on.
    3 days later after all was fine it happend again a first I thought it was coilpack or spark plugs changed both and problem still there but this time its not going away.
    After closer inspection there looks like oil or petrol running over the shield on the exhaust manifold also had alook on the floor and its dripping out.
    I am now thinking the Head Gasket has gone so took it to work and have now just had a compression test and all 4 Cylinders are coming back with 225 PSI so there all fine.
    Any Ideas its going on the ramps at 12 but im at a loss now it cant be anything to do with the ecu can it becuase its leaking oil/petrol out well i think its petrol anyway.
    Any Help greatly appreciated
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    how do you know it was number 2 have you ever had a fuel pressure sensor change
    Jan 2010
    glasgow
    could it be the hp fuel pump thats went and leaking petrol in to the engine? make sure all the pipes are ok no splits and the injectors are not leaking at the o ring seals and the fuel presure regulator isnt leaking at its seal
    Apr 2008
    Liverpool
    Found the problem cracked head!!!!!
    Aug 2010
    Luton
    ouch !!!!!
    Apr 2008
    Liverpool
    If anyone knows were I can get a Head from it would be appreciated as Im having no luck.
    Seen one on Ebay for 650 but I can buy a 2.0 turbo engine for 750 and try and make that fit.
    650 is a stupid price for a head
    Jan 2010
    glasgow
    yip its way ott mate i seen that on the bay there is also a full engine for £650 or there abouts some times they can repair a crack in a head mate have you had a word with some of the firms that do the skimming etc?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    My mate had a cracked head on his 2.0DTi and had a lot of pressure in the header tank! Are you sure the head is cracked? Could be a burnt valve?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
  1. major power loss and engine noise
    By martin.lake in forum Engine & Drivetrain
    Last Post: 17th September 2012, 00:13
  2. Replies: 35
    Last Post: 5th May 2012, 15:32
  3. 2.2 direct petrol 05. Fault codes
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 15:35
  4. 2.2 direct - guess the fault!
    By Jaffatubes in forum Engine & Drivetrain
    Last Post: 13th January 2010, 23:47
  5. Sick Signum 2.2 Direct (Fault Codes)
    By kaston in forum Engine & Drivetrain
    Last Post: 13th September 2007, 10:31
