Thread: Removing headlight ???
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default Removing headlight ???
    Hi guy's, Some T**t hit my car on the front wing breaking the bottom lug of the headlinht unit. I removed the 2 top bolts but can't manage to get the unit out of the gap to replace it, Am I missing something. It moves up & outward by about 2 inches then jams
    P.s has anyone used the after market units on ebay & are they good quality.
    SOMERSET
    Quote Originally Posted by 111
    Send a pm to Big Phil, he took his out at Santa Pod, it did involve loosening the bumper though !!
    ohno he didn't ..his pit crew did it for him!!
    take one side of the bumper off, or remove it all together. there is another fixing behind the bumperline..
    Stockton-on-Tees
    Quote Originally Posted by Gsi3.2
    How easy is it to remove the bumber
    1
    [Ex]Admin Duncan's Avatar
    SOMERSET
    1
    Really EASY, just make sure somebody else does it for you GSI3.2
    Stockton-on-Tees
    1
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The most difficult part I found was removing the push in studs under neath. Make sure you turn your wheels right over to the side so you can get easier access into the arches.
    Stockton-on-Tees
    Will do
  1. Removing air pipe (?) to get at driver side headlight
    By thiscarofmine in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2011, 14:50
  2. advice on removing the whole headlight unit
    By dti owner in forum Bodywork & Interior
    Last Post: 6th February 2011, 20:39
  3. Removing blue connector on headlight switch
    By Reading1800 in forum Bodywork & Interior
    Last Post: 5th June 2010, 11:04
  4. Removing socket on headlight?
    By Friel in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 15:55
removing vectra c headlight
