Thread: 3.2 V6 Gearbox
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Default 3.2 V6 Gearbox
    Sorry if this thread has already been talked about, i've used the search facility but couldn't find an answer to my individual niggle.
    I find it extremely difficult to get the damn thing into 1st gear, i really do have to wrestle with it. Once i'm moving the gear change is ok and suppose i'm approaching some lights and dip the clutch and change down through the gears it goes into 1st ok, but if i stop at some lights put it into neutral and let the clutch out, once i dip the cluth again and try to get it into gear i really struggle, i like have to put it into 4th first then into 1st.
    Does any one elses do this, if i mention to Vx under warranty are they likely to fob me off?
    If the car is under warranty they cant fob you off...and believe me m8...VX know theres a prob with some of the V6 g/boxes...so get it back into your dealer and dont take no for an answer
    There are a couple of threads on this problem.
    http://www.vectra-c.com/forum/showthread.php?t=821 was one of them.
    HTH
    Out of interest, what gearbox has the 3.2 & 2.0 turbo got in it
    The 2.0T has the F40 (six speed Close Ratio). The 3.2 V6 has the F35 (5 speed Wide Ratio) that is if you're meaning manual boxes? The 3.2 V6 has the option of an auto box (AF33).
    HTH
    Thanks Duncan.
    No probs
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
