Thread: Front bumper- popping off!
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Default Front bumper- popping off!
    A little job (well hopefully) i want to sort out. the corner (top) of front bumper drivers side is away from the bodywork. you can nearly see the slots at the top of the bumper, but when you push it in it feels like its not clipping onto something properly and just springs back out. Ive taken the 2 wheel arch screws out thinking i could clip bumper back on then re-fit screws, but made no difference! Any ideas?
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    sounds like the clips were broken then
    Dunstable
    When you undo the screws in the wheel arch, you need to push the bit in where the top screw is. There is a sliding bracket that locks the side of the bumper in when you do up the top screw in the wheel arch, but you need to push the bracket forward when you undo the screw. Once you've done this, push the part of the bumper in that's sticking out, and do the screw up again. If you take the bumper off you'll see what I mean. I had this after removing my bumper, the top sides by the headlights were sticking out. It's all fine once you know how it all fits together
    Nov 2010
    Leicestershire
    What clips? Where are they located? so something should clip into slots? If they are broke, can they be replaced?
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    yes they can .dont know the part number tho ..but i'm guessing someone will
    Dunstable
    There are no clips on the bumper on the facelift, only underneath to hold the undertray in place. The bit that pulls the top of the bumper in either side is a sliding bracket.
    Nov 2010
    Leicestershire
    So it might be worth taking the inner arch out to see the slider?
    Nov 2010
    Leicestershire
    Right, just been out to have a quick look (its cold!) and the top arch screw is not doing anything (it moves side to side when you push the bumper in!) and looks like a cheap plastic plug screw, different to the others, so if i get the correct screw it should be ok?
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
  2. bumper keeps popping out
    By Morephun in forum Bodywork & Interior
    Last Post: 24th January 2011, 02:23
  3. Replies: 8
    Last Post: 11th March 2008, 19:28
