Results 1 to 10 of 11
Thread: Smells like an old transit
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Default Smells like an old transit
    I've noticed in the last couple of weeks that the 3.0 CDTi Siggy has started to smell more and more like a diesel, if that makes sense.
    It used to have that sort of chemical smell that catalysed diesels tend to have, but lately there's definitely a pong like an old transit van from the exhaust. I thought it was Asda diesel, but the last two tankfuls have been BP, and it's still doing it.
    Is this a sign of impending massive expense, or am I worrying over nothing? Fuel consumption is the same as ever, and there are no warning lights.
    Thanks, Phil
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Just get it nice and hot and give it a good blast down the motorway at high revs. Blow all the crap out. That sorted mine
    Sodding Typical on Sea
    Might be the anti-waxing winter formulation of diesel contributing to that as well I wonder?
    May 2006
    scotland
    it could be something blowing exhaust fumes under the bonnet and being drawn into thecabin via the pollen filter drain hole, just like my 1.9cdti has started doing ovre last month. In my case it is a leaking manifold.
    Luton, Beds
    Don't think it's that -it only smells outside the car.
    As far as I'm aware the 3.0 doesn't have the manifold "issues"
    Phil
    Dont the fuel companies put an additive in diesel in the winter to stop it waxing?
    Oct 2007
    Shropshire
    Defo try a hard run at high revs to try clear it first. You don't have to speed just do it is second!
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Hi, the 3.0 cdti has a dpf filtter and i think a cat !
    maybe its not heating up the exhaust gases !
    or could just be an injecter fault !
    Quote Originally Posted by Kcs View Post
    His is a 2004 model so i doubt it has a dpf as my 03 plate didn't. Only the euro 4 engines have them.
    I still wonder if it's the winter additives that are smelling more than normal.
    Regular Member i5aces's Avatar
    andover
    did you ever get to the bottom of this i posted not long ago my 3.0 is doing exactly the same only smells outside the car and is a really strong fuel smell
  1. getting rid of smells
    By Swedge in forum Detailing and Car Care Discussion
    Last Post: 15th December 2012, 16:01
  2. Air con smells!
    By dayvo in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2011, 13:20
  3. oil smells and seems to be topping its self up
    By sharpy22 in forum Engine & Drivetrain
    Last Post: 8th June 2010, 17:37
  4. Aircon smells
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2010, 23:55
  5. It smells so good I want to eat it....
    By DeathStar in forum Detailing and Car Care Discussion
    Last Post: 16th March 2008, 12:16
