Thread: help regarding idle setting
    Nov 2010
    leighton buzzard
    Question help regarding idle setting
    hello does anyone have any idea how i can adjust the idle on my vectra c petroll 2.2 sxi
    Nov 2010
    nottingham
    clean your throttle body and egr valve pal
    Engine : 1.9 CDTi
    Has it just changed?
    Why does it need adjusting?
    Its set in the ecu I think so would need Tech2 or Op-Com' ing
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 2.8T 280 vxr
    Trim : 280 vxr
    Engine : 2.8t
    Dunno what other engines idle like but mine had always idled pretty low, unless got air con motor running in which it increases to like 850+
    13 Post(s)
    What does it usually idle at?
    My 2.2 petrol usually sits around the 700 rpm mark. It still sits at this value with the climate control and anything electrical switched on.
  1. Torque setting
    By shaun.b in forum Engine & Drivetrain
    Last Post: 11th December 2012, 20:46
  2. No fan on setting 1?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 18:05
  3. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. Trouble Setting Off
    By Chilie in forum Engine & Drivetrain
    Last Post: 5th June 2008, 12:43
