Thread: Replacing suspension bits
    SCOTLAND
    Default Replacing suspension bits
    Looking at replacing some suspension parts after crimbo if i'm keeping the car which it looks like i will be doing for a while. I fitted new sprins and shocks just under 2 years ago but rest are original parts (93k miles ) so could do with updating.
    Am i right in thinking i need the following:-
    FRONT
    - ARB Bushes
    - front stabilizer drop links
    - front wishbone arms
    REAR
    - Upper and lower control arms
    - ARB bushes
    Anything else i'd need? Wonder if trade club discount would apply or be any good on these.
    East Midlands
    All the parts you mention only need renewing if they are cream crackered.
    Arb can cause a squelching sound when going over speed bumps.
    Front drop links make a metalic knockng sound when going over SH .
    Front wishbones,dont normally have that many probs with these.
    Rear upper control armes when knackered make a knocking sound from rear,there a simple test for them..do a search.
    Rear ARB bushes are very easy to change on rear and cheap so may as well do these.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Graeme View Post
    FRONT
    - ARB Bushes
    REAR
    - ARB bushes
    Thats about it mate unless you want to go to the lengths of replacing the upper strut mounts and bearings and possibly the rear arb drop links. Prevention is far better than cure.
    You might want to get some the uprated Saab front droplinks from partsforsaabs.com
    Trade club should be ok on most of those things as they are wear and tear items
    SCOTLAND
    Quote Originally Posted by macdad View Post
    Ah right cheers mate. Definately my front ARBs then not had any other major knocks but the front drop lonks look cheap so might get them done if doing the bushes anyway.
    swansea
    Whats involved in changing the front arbs.
    Jun 2006
    Kirkintilloch, Scotland
    FRONT
    - ARB Bushes
    REAR
    - ARB bushes
    I would do the upper strut bearing whilst your in there. When replacing a front spring at 55K I found one of the dampers and an upper bearing grinding a wee bit so as a believer in preventative maintenance replaced the lot - struts, upper bearings, springs, drop links and ARB bushes.
    Didn't do the wishbone arms though. Are they known to be a common problem?
    Dave
    spoons
    Guest
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by jrh1 View Post
    Changing the anti-roll bar itself? More hassle than it's worth, unless there's something wrong with it. If you mean the bushes for the ARB, just unbolt the droplink from the ARB, then undo the two bolts that hold the bush in place - reaching in and turning these bolts a bit at a time (which is all there's room for) is the toughest bit.
    best tool for this is a 10mm ratchet spanner
    S.E
    Quote Originally Posted by marktaylor View Post
    10mm, yes; but I found that although the bolts were too tight to turn with your fingers, they were still too loose for the ratchet to work.
  1. Replacing rear suspension and brakes
    By pody in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2011, 01:06
  2. New suspension bits ordered.
    By Ian-Highlander in forum Handling & Braking
    Last Post: 23rd August 2011, 17:21
  3. Replacing The Standard Suspension Help
    By Kev_G in forum Handling & Braking
    Last Post: 18th October 2009, 18:09
  4. Removing/replacing suspension struts?
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2009, 20:52
