Thread: Help bleeding the heating system on vectra c 1.8 ls
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Default Help bleeding the heating system on vectra c 1.8 ls
    Has anyone got any step by step pics on what the do to bleed the coolant system as i think i might have a air look as the heaters in the car are only coming through warm
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    What temperature is the engine running at? White s few members have had to change their engine thermostat as they are keeping the engine temperature low
    13 Post(s)
    Shouldn't need to bleed it as it's a self bleeding system. The expansion tank is above the engine for a reason - that's where any air in the system will end up.
    What might be wrong is one of the servos on the heater has stuck. You'll need to remove the glovebox to check.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    And another thermostat bites the dust.................
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Didn't know this as when i changed my thermostat i took cap off and ran car upto temp to get rid of any air in system
    Irmscher Insignia CDTI 130
    13 Post(s)
    Quote Originally Posted by bigmac View Post
    As you say, that is the correct proceedure. Forgot to mention about removing the cap.
    As any air ends up at the highest level of the cooling system (ie, the header tank) it can just vent out the tank.
    SHEFFIELD
    Ive done thattaking the header tank lid off and ran it to temp and the temp on the car goes up just above 80 and stays there but the heaters in the car is still only warm ive also put a new stat in it and flushed the matrix though and checked the flap under the glove box and every thing seems ok and what i should be no over heating but still no heaters working right on 1 they are hot but put iton 2 3 4 they then cool down im frzzing anyone got a clue before i take it to the dealers and have to remorgage the house to get it fixed
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. Signum Heating System Problem
    By Lotus_c_man in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2009, 14:04
  3. 2.0 DTI Bleeding Fuel System
    By jay81 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2009, 06:11
  4. Pre Heating System??
    By blanch in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 13:29
  5. sludge in central heating system
    By moorlander in forum The 'Off Topic' room
    Last Post: 27th September 2008, 08:06
https:www.vectra-c.comforumshowthread.php123534-Help-bleeding-the-heating-system-on-vectra-c-1-8-ls
vauxhall astra j cooling system bleeding
Where is the bleed nipper on a vauxhall vectra c
how to bleed coolant on vectra c
vauxhall insignia coolant system bleeding
How to bleed cooling system 07 vectra
vauxhall zafira 1.8 water bleeding
Vectra 2007 bleed coolant
how to bleed vectra heater
vectra c flush matrix
vectra c 1.8 coolant replace site:www.vectra-c.com
how to bleed heater system on a 2006 vectra 1.8
bleeding the heater on vectra 2007
how do:you bleed the air from a vectra cooling system
bleeding the cooling system on a vectra c
vectra c coolant bleed
insignia how remove air from cooling system
bleed cooling system vectra c 1.9cdti
how to bleed vectra c heater
how to bleed vectra c cooling system
how does the cooling system work on vectra
How do I bleed my vauxhall vectra c heating system
bleed heater matrix vectra c
vauxhall vectra 1.9 cdti heating systems
vectra c bleeding heaters
