Thread: Shaking/vibrating chassis a
    Nov 2010
    holland
    Default Shaking/vibrating chassis a
    Hey,
    I drive a 2006 model C GTS, and i have te following problems. From the start that i bought the car it shakes/vibrates in the chassis. It has a IDS Sports chassis.
    The dealer dit the following things;
    Replace front tyres (michelin pilot 215-50-17 )
    Re-balance weels (6 times allready)
    Allingment of car
    But nothing helps, they checkt all the chassis and the suspension.
    Also i had the following sybol's in my display, dealer say's he can't find anything...
    One is the sign of a traction control, the other is a small shock whit a !.
    Both signs go out when i restard the car, but it worry's me.
    Any one an idea?
    Regular Member signumturbo04's Avatar
    SCOTLAND
    check inner cv joints for the shudder as my signum used to do it and took ages to discover that they were the problem. dunno about the warning lights though
    Nov 2010
    holland
    Quote Originally Posted by signumturbo04 View Post
    You meen te gearbox CV or wheel side?
    SCOTLAND
    cv joints at gearbox end. meant to say only takes a tiny amount of play to maker them vibrate
    Engine : 1.9 CDTi
    Sounds like your dealer needs a kick.
    Because you have the IDS suspension the ecu can electronicly adjust the shocks. Thats a fault light telling you there is a problem.
    Nov 2010
    holland
    I think they are tring to .... me. The warrenty stops over 6 weeks, and the shocks kost arround €1600 to replace for 4 pieces. But they say there's no faulth code's in ECU. First let them replace all the CV's on axle, An idea about costs?
    preston
    can you remove IDS monitoring from ecu?
    Then get Bilstein B8 at half the price + some nice eibach springs to boot.
    thats what i'd do.....I'd be speaking to someone with Tech2 to see whats possible
    Nov 2010
    holland
    Yes but driving orginal is nicer, no fault codes and troubles, also i still have warrenty let them solve it and pay it! And wi'll get a second opinion somewhere.
    Nov 2010
    holland
    Well the fauld code of the shock and traction control whas fixed, it whas a calibration error in steeringwheel possition sensor. The shaking is still not solved, the dealer refuses to replace CV's because the shudder doesn't go when you apply clutch, they say that way its proved that it isnt in the joint's/axles...
  1. Odd shaking - Am I going mad
    By Tim525 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:31
  2. shaking whole car
    By alijlacy in forum Vectra C / Signum Troubleshooting
    Last Post: 15th December 2010, 17:20
  3. Help with Chassis number, Please!!!!!!
    By Paul Bennett in forum Vectra C / Signum Troubleshooting
    Last Post: 12th June 2009, 22:39
  4. Shaking 3.2?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th September 2008, 08:03
  5. Chassis
    By mshaw in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 22:12
