Originally Posted by
barney490
Not heard of this problem on the estate, usually the darn things stop halfway through closeing. If you havn't already done so, try your spare key, just incase its a button issue on the fob. Might also be worth popping out the switch on the tailgate and checking the wires haven't worked loose, they are just a spade connection. While the button is out, you could try connecting the wires briefly with a paper clip opened up, to mimmic the switch operating. If the tailgate closes, it's a faulty switch.
