Thread: Engine Temp.....
    Regular Member skip85's Avatar
    Feb 2010
    Wiltshire
    Vehicle : vectra c estate
    Trim : Design
    Engine : 1.9 cdti 150
    Mileage : 150000
    Default Engine Temp.....
    Hi All,
    My 1.9 150 CDTI used to run between 80-90 on the dial. It now wont get above 80 even before cold weather started. Any ideas please?
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Sounds like the thermostat is stuck open.
    PRESTON
    Feb 2010
    Wiltshire
    Trim : Design
    Mileage : 150000
    Will it damage engine much if left?
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    mines the same m8 remember the air temp is much lower than normal
    turn off your heater and it will quickly rise above 80
    PRESTON
    Quote Originally Posted by skip85 View Post
    Nope, won't harm the engine, fuel economy might suffer as engine not getting to temp, but tbh they ain't that bad to change, a little bit more fiddly on 120 models.
    Regular Member kamar's Avatar
    bradford
    mines usually around there but i put it to weather if i gave it a few gears it will reach 90 no probs..
    i drove from work last night it was -7 an the temp didnt move it was an 8 mile journey mostly up hill... but it blows warm air after afew mins...
    Feb 2010
    Wiltshire
    Trim : Design
    Mileage : 150000
    Ok I'll try turning heater down and see what happens. Is there a how2 for changing stat and how much does anyone know?
    Oct 2010
    London
    Mine is seriously struggling to get above 80c now... I have to drive it hard to get it there. If you have the heaters on anything above fan 1 then no hope!
    Stat stuck open?! Or is this just a very cool running engine?! Late 2008 CDTi 150...
    Feb 2009
    jilava
    I've changed the thermostat about a year ago for the same reasons, temp guage was below 80 deg most of the time, and was very good (around 88 deg) until about 1 month ago when it started to drop at around 80 again... are they only supposed to last for 12 months?! does anyone know of a good thermostat manufacturer/brand?
  1. what should teh engine temp be in 1.9 150
    By kirky2k4 in forum Engine & Drivetrain
    Last Post: 26th January 2011, 22:16
  2. Engine Temp
    By bigmac in forum Engine & Drivetrain
    Last Post: 17th May 2010, 20:36
  3. Engine temp vvt
    By shadyone in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 19:11
  4. engine temp
    By iasha in forum Engine & Drivetrain
    Last Post: 27th January 2010, 00:39
  5. engine temp.
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 21st October 2009, 19:56
