Hi got myself some Angel eye's(depo) and fitted in on Sat, but later at dusk found out they were switched for Lhd i know there is a lever to flick them over to rhd just cant find it plz any help anyone.Thx's
I am pretty sure they can just be changed but I don't have any myself. Don't worry someone will help!
i found out my old ones could be changed too
yep there is a little lever to move..........wont be easy now they are fitted ...there is a picture somewhere in a thread showing you the lever...
the picture was on photo bucket and now gone ...but this might help as the op was struggling to find the lever .
Update lads!!
Well, there was certainly nothing resembling the very clear and well thought out lever on the oem lights!
I found the little ****** away on the dipped beam enclosure.. basically a piece of coat hanger with a curled end! Was real awkward too because, when I went to drop the bumper for a good look see I saw the guy who done a few repairs and fitted a new bumper a while back decided it was too much bother getting the black vx push fasteners for where the bumper comes up to the front panel, so stuck a few dirty great metal rivets through the two!
Finally figured out that it worked kinda like a safety pin to move it..ie: push it in a bit to release then move up or down til it catches in position for lhd or rhd
The yellow instruction stickers were there, but I found them very unhelpful, and only really understood the line diagram after I had sussed what the setup was by meself, also (and I must just double check) the advised postion for lhd/rhd were in reality the other way around!
Anyway, got it sorted, and a friend of a friend aligned them for me tonight with the right gear.. hope she passes the mot in the mornin now!
So, if anyone with these depo, Ultimate Styling lights needs to adjust the directionality the lever is in on the side of the dipped beam metal casing and it will feel like a bit of coat hanger!
Thanks!
Sorted it today plus my fingers are still in one piece thx's gent's for the info![]()
