Results 1 to 10 of 15
Thread: tailgate lights not working
    Nov 2010
    derby
    Default tailgate lights not working
    hi just noticed my tail lights aren't working had a look at the manual says nothing under there about being a fuse unless its linked with something else or it could be just the bulbs any ideas?? car is a vectra c v6 cdti
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    what of the lights arnt working? checked bulbs? fuses in the rear electriccenter?
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Insignia 2.0 CDTI 4X4
    Trim : Sport Tourer, Cosmo
    Engine : A20DTH
    Year : 2011
    Also check the plugs of the wirings.
    Devon
    Tail lights on passenger side not working but bulbs OK
    Have something similar, taillights on passenger side are not working (reversing and rearlight). Vx has once changed wiring loom which made the passenger side brighter than the driver side. Over time they got dimmer and dimmer, now they both cause the warning about bulbs to come up all the time. Nothing wrong with the bulbs themselves...
    Anyone seen something similar? Where could the fault be?
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    I had the same problem mine turned out to be the multi plug had come lose, just pushed it back and the problem solved
    Devon
    Quote Originally Posted by Badger59 View Post
    Hi Badger59,
    You mean you also had problems on one side of the tailgate? If so, where can I find that multi plug...perhaps silly question but I'd like to fix it if possible so any instructions as to where and how, then yes please!
    Cheers,
    Mark
    Regular Member pitsmoor21's Avatar
    Apr 2008
    sheffield
    Quote Originally Posted by mvdg View Post
    Hi Badger59,
    Cheers,
    Mark
    did you sort this out as my warning light for bulb has come on but none of the bulbs have blown. Im sure theres a light out on both sides
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    hi pitsmoor21 i had the bulb light come on the dashboard it means one bulb is on its way out but also when its really cold the bulb light comes on.
    but i have not seen the bulb light on the dashboard for a while now must be the weather.
    Apr 2008
    sheffield
    1-Turn signal light
    2-Tail light / brake light
    3-Tail light
    4-Fog tail light
    1)
    5-Reversing light
    im certain that 3 is now acting as brake light aswell and number 2 isnt working at all very strange lol i took the brake fuse out earlier and when i started the car i got engine management light on which i read as
    2103 antenna not connected
    1565 door ajar circuit short to battery
    0170 fuel trim malfuntion
    0671 cruise control/brake switch a circuit malfuntion
    now theres only the 0671 what would make sense to me but the others hopefully are old codes
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Quote Originally Posted by pitsmoor21 View Post
    1-Turn signal light
    3-Tail light
    4-Fog tail light
    1)
    5-Reversing light
    check the main lights on the back
    i had this problem the red lights would be on either side of the car
    but 1 was not lit up under the red light
    i hope this makes sence
  1. No working rear lights or tailgate
    By TonyP2020 in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2016, 21:56
  2. power tailgate and flashing hazard lights
    By jaqubek in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 14:51
  3. tailgate light cluster not working on o/s
    By leesheridan in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 16:54
  4. Clear tailgate lights
    By krzyzu in forum Parts for sale
    Last Post: 3rd March 2009, 21:05
  5. 382 bulbs and tinted tailgate lights
    By krzyzu in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 22:08
https:www.vectra-c.comforumshowthread.php123510-tailgate-lights-not-working
