Results 1 to 10 of 22
Thread: Winter & Washer Jets
    Lincs
    Default Winter & Washer Jets
    What's the answer? I have 50% super-concentrated fluid in the washer bottle,but still i get no spray. I have put de-icer on the jets,hot water on the piping and the washer bottle but to no avail. Sometimes the pump can't even be heard running.
    Very frustrating when i get as prepared as i can for winter,but still end up with a squirty bottle in the car that i have to spray the screen with as and when i can.
    Any tips please?
    Paul.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    put some hot water in the bottle mate
    Lincs
    Quote Originally Posted by paulvectrac View Post
    Only prob there mate is the bottle is full of concentrate,i can't get anything else in.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    o ok mate lol
    Sodding Typical on Sea
    You need the heat from the engine to thaw the pipes ot and allow the concentrate to circulate as most likely the bottom of the bottle is frozen and the small bore pipes too
    Lincs
    Quote Originally Posted by Derek Mc View Post
    Still no luck there i'm afraid as i did 150 miles last night(ok it was -6) and not even a dribble from the jets front or rear.
    I'm guessing i'm stuffed due to the temps
    Londonderry
    Get yourself some Comma Xstream it protects down to -60 and I have never had it freeze using it 1:3. Also took the insignia wassher jets off as the ice up quite quickly and put some heated ones in their place. No issues so far
    Comma Xstream 3 For 2
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds more like there blocked mate not frozen. Over time you get gunk in the bottom of the bottle from additives. I only use water and when its very cold Halfords pre mixed stuff.
    You could fit the heated washer jets, but odds on you need to flush the whole system out.
    Lincs
    Quote Originally Posted by cdti_sri View Post
    That was the ONLY advantage i had owning the TDCI as it had heated jets.
    Lincs
    Oh right, it's difficult to tell what's going on as the max temp today here is around -2. If it gets above freezing and still no joy i'll do the flush as you say cheers.
  1. washer jets
    Last Post: 11th November 2011, 20:18
  2. washer jets
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 07:40
  3. Washer jets.
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2010, 18:22
  4. Washer jets
    By DHobbs in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2010, 16:04
  5. AFL washer Jets
    By CorsaVan in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 19:18
