Thread: Vectra c hand break help adjusting
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Default Vectra c hand break help adjusting
    Hi ive just had my car in for the mot and its failed on the hand break having to much travel ive just put some new rear pads into as i was told it would tightern the hand break up but its not its the only thing thats stopping the car passing the mot as anyone got any ideas can u adjust it yourself i know it does adjust on it own but stuck with it now
    Sodding Typical on Sea
    Try this,
    As far as I have learned it is self adjusting this explains how others carry that process out.
    http://www.vectra-c.com/forum/showth...ake+adjustment
    Mileage : 000
    When you put the new pads in did you press the footbrake pedel first?? As in doing so it will take up the "slack" in the pads after refitting. If you pull the handbrake lever first it will take up the slack instead, and may loose the "auto" adjustment on the handbrake.
    SHEFFIELD
    Yes when i changed the rear pads i pumped the break peddle first the applyed the hand break about 10 times and still not worked still seems quit high can u adjust the cable or is there any thing to adjust the hand break cable slack
    Regular Member Dazzy2006's Avatar
    Notts
    Handbrake is self adjusting so if you have already done the adjusting procedure you have a few options
    try the adjusting procedure again
    handbrake cable could have stretched - replace
    handbrake self adjuster slipping - replace handbrake assembly (expensive)
    Good luck
    SHEFFIELD
    Just an update I've just had a letter from vaxhall for a recall on the hand break does any one know off this it says in the letter that all vectra and sigm,s have a fault on the handbreak so if u have one from 2002 and up wards and are having a problem with the handbreak give vaxhall a ring u may find that there is a problem and they will sort it this is new to me so if anyone has already done this with the recall let me know what your out come was as I've only just got a letter today so I'm only saying what it says on the letter guys
    SHEFFIELD
    Hope this helps you all that may have any problems with your handbreak
    Notts
    The recall replaces a spring so your handbrake doesnt come off on its own - i'd get it done and see if the mechanic can suggest a way of adjusting the handbrake
    Quote Originally Posted by 0114NIGEL0114 View Post
    Search for "handbrake recall" on here. Already a couple of threads on it plus loads from when it was first discovered. Its about it releasing itself, nothing to do with adjustment etc.
    http://www.vectra-c.com/forum/showthread.php?t=124085
  1. hi iam a happy vectra c break driver
    By rinuske in forum Introduce yourself.
    Last Post: 7th January 2010, 23:31
  2. vectra c 1.9 8v adjusting notchy gear linkage ???
    By lollypop in forum Engine & Drivetrain
    Last Post: 26th April 2009, 14:24
  3. rear break problem Vectra Sri
    By universalwoman in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2009, 18:35
  4. Vectra C break from Belgium
    By wheelin75r in forum Gallery
    Last Post: 14th October 2008, 09:19
handbrake cable adjustment vectra c 1.9
