Thread: Diesel Filter leak
    Mar 2007
    Gloucestershire
    Default Diesel Filter leak
    Was sorting out my egr problems this morning and noticed that there was diesel dripping from the bottom of the fuel filter when the engine was running. I have checked the two pipes going in and they dont appear to be leaking, but think it may be coming from the bottom of the housing. Is there a sensor on the bottom? Any ideas if you can lift the whole unit out? I was wondering if a sealing washer has gone?
    Any ideas welcomed!!
    Car is 1.9cdti
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    its a drain for water!, try nipping it up by hand carefully!.
    Engine : 1.9 CDTi
    If the housing is leaking give me a shout as I think I have a spare one
    Mar 2007
    Gloucestershire
    Quote Originally Posted by the-wizard View Post
    excuse my ignorance but how do you mean nip it up? I can seem to lift the entire housing up so far but then it seems to stop. It also only seems to leak when its under pressure, i.e. with the ignition on or when running - although just been on a run and it appears to have stopped.
    Mar 2007
    Gloucestershire
    Thumbs up
    Quote Originally Posted by lee gsi View Post
    Thanks! I will try and get it out and see if the housing is gone and let you know
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    the water drain bung thingy underneath may just need tightning slightly.
    Aug 2010
    Stoke on Trent
    Just changed my Diesel Fuel Filter today and noticed the housing was loose in the surrounding cage (old filter was absolutely minging by the way.... it made the one in the forum how-to look positively virginal)... anyway... when I got the housing out I noticed at the rear there was allot of broken sticky-out plastic bits .... well the filter is now changed and the housing is wedged into the cage with cardboard to stop it rattling ....
    ...so lee gsi... if sri150 doesn't want/need the housing you have.. I may be interested...
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diesel leak
    Last Post: 6th January 2013, 22:53
  3. diesel leak
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2011, 20:57
  4. Need urgent help with a diesel leak
    By the_wave_rider in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:42
  5. diesel leak ??
    By danceade in forum Vectra C / Signum Troubleshooting
    Last Post: 12th February 2008, 02:09
leak from diesel filter
vectra c diesel filter loose
1.9 cdti diesel filter loose
vectra diesel filter leaking
vauxhall vectra plastic diesel filter comes loose forum
