Thread: headlight problem
    Sep 2010
    hampshire
    Default headlight problem
    yesterday got a warning to check my drivers side headlight, did this and found i needed a new bulb went and got one fitted all fine, jumped in car and started it up and got another warning to check my front drivers side parking light, basically the indicator is stuck on, its not flashing just a solid light and when i give it a slap it sometimes goes off. i must of knocked something when fitting new bulb anyone got any ideas ? iv tried to take the whole headlight out but it seems stuck on something. does it just need a bit of force or do i need to wangle out ? any help is greatly apreiciated.
    Regular Member mozzer99's Avatar
    bristol
    Whole headlight out needs the bumper removing for the sake of the bottom fixing - bad design .......
    Sodding Typical on Sea
    Try removing the electrical connector and spray with contact cleaner spray first as the amount of items that you could disrupt are few so try this first.
    Sep 2010
    hampshire
    thanks for that, shame headlight doesnt come out as there aint much space for a bloke with big hands like me, going to have a look soon and get my car ready for this snow if it ever comes, got myself loads of screenwash antifreeze de icer etc etc and it aint even snowed yet.
    Glasgow
    I find its easier to remove the air feed to the airbox and also the airbox when it comes to the drivers side headlight, tons of room and its only a 5 min job.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is it on all of the time or only when you switch the lights on?
    Sep 2010
    hampshire
    all the time, just been out to try fix it and had no joy, thought id fixed it it went out i got in car no warning light did i few other jobs then bang it was on again with warning light.
    13 Post(s)
    Quote Originally Posted by vvcsri View Post
    jumped in car and started it up and got another warning to check my front drivers side parking light, basically the indicator is stuck on.
    In the event of a front side light failure the indicator takes over the role so that the corner of the car remains illuminated and people can see you.
  1. headlight problem?
    By jungle in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 23:51
  2. Self Levelling Headlight problem?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:22
  3. Headlight problem
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:27
  4. pre-facelift headlight problem
    By the-ferret in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2008, 20:31
  5. Headlight problem.
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2007, 18:37
