Results 1 to 10 of 13
Thread: VECTRA "B",ODOMETER BULB CHANGE.Is it difficult?.
    stockport
    Thumbs up VECTRA "B",ODOMETER BULB CHANGE.Is it difficult?.
    The bulb has gone out on my son's Vectra "B's" odometer and he can't read the mileage.Not that it's a problem in itself,but he's a bit worried that it may be an issue when his MOT comes round again.Are they difficult to change and how do you go about it?.Thank's in advance. FELIXX.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    nah, its a little fiddly but nothing to be scared off, I did one early last year on one of mine.. I picked up a spare bulb from a scrappy near me as most have the clocks ripped open and the bulbs available.. took me less than an hour..
    stockport
    Arrow
    Quote Originally Posted by Caveman_nige View Post
    How do you access the binnacle to get at it,do you have to dismantle half the dashboard!!!!?. FELIXX.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    hmm good question.. i can hardly remember.. i think i removed the steering wheel suuround and then that revealed the plastics that surround the dash and vents, the clocks i think were held in with a couple of screws and then just pulled out..
    stockport
    Thumbs up
    Cheers for that.It gives me some idea of where to start without messing things up.I'll get on to it tomorrow,(so long as the snow stays away!!). FELIXX
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by felixx View Post
    I helped a mate do one a couple of years ago. Had to remove the steering wheel (it had the non-adjusting one, so could not pull forward/down) to get to the surround. Then removed the surround, then the clocks themselves. Took about an hour to remove everything.
    HINT --- Change all the bulbs while you have it off!!
    Had to get a certain tool from VX to remove the steering wheel.
    Took about 20 mins to put back together.
    Hope this helps!
    stockport
    Thumbs up
    Quote Originally Posted by tony-1977 View Post
    Hope this helps!
    Thank's for that,I was going to do it for him,(thought it would be a quick job,isn't it true when they say ignorance is bliss),but under the circumstances he can do it himself!!!!!!. FELIXX.
    13 Post(s)
    Halstead, Essex
    When I had my Vectra B, I've changed all the bulbs with blue led's and I followed something close to the how 2 posted by Big Dave here. And no, you don't need to take the steering wheel off. But be careful not to break the lower plastic bits when you take the speedo out (I did). Adrian
    Did this a million time on my old Vec B's - never removed the steering wheel. The hardest part was removing the dash vents I found, after that it was plain sailing really...
  1. Replies: 1
    Last Post: 5th January 2013, 01:37
  2. Replies: 32
    Last Post: 2nd January 2013, 02:18
  3. outside temperature display's "F" on the display after battery change
    By Philhammond2004 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2012, 19:12
  4. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  5. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
how to change dash lights on vectra b
vectra b odometer
how to replace bulbs on iNSTRUMENT CLUSTER Vauxhall Vectra 2007
how to replace dashboard lights vectra b
Opel vectra b odometer
vectra b dashboard light bulbs
how to take the clocks out of a vectra b
Opel vectral b odometer malfunctions
vauxhall zafira b mileometer light out
vectra b sri cant see mileage display why is this
vauxhall zafria odometer bulb replacement
vectra b mileage bulb
vectra b dash bulbs
vauxhall vectra cant see odometer
odometru vectra b
opel vectra b change lights
vectra odometer bulb
how to change dashboar lights b vectra
