Results 1 to 10 of 25
Thread: Is there an alternative to HID's?
    Regular Member Innes's Avatar
    Plymouth
    Default Is there an alternative to HID's?
    Driving home from tesco tonight the wife commented on how crap our lights were. I'd read on here that the vectras headlights weren't that great and explained to her that alot of members on here have HIDs. I'm a bit hazy on the legality of them.
    Will they pass an MOT?
    Will the police pull me for having bright lights?
    What are the alternative to HIDs?
    Regular Member signumturbo04's Avatar
    SCOTLAND
    my car passed mot today with them fitted. i asked the tester my m8 how legal hey were and he says that aslong as they are aligned correctly and show the correct beam pattern that there is no problem with them. and as for the mot rule thing next year he says thats a load of ****E
    Bristol
    As above!
    Just get 4300k or 5000k, some say 6000k are also OK with slight blue tint. Go any higher than that and the colour becomes noticable and then you'll get trouble from plod.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mine passed mot with 8000k in mine plus min of drivin did a stop cheack and it was still ok
    Plymouth
    I had a look at the how2 section and it looks a little fiddly. Having said that I saw the on HIDs-direct http://www.hids-direct.co.uk/50w-vau...its-p-445.html has anyone fitted them? Is it really plug n' play? How easy was it to fit?
    Also as per the thread title is there an alternative to HIDs? Are there brighter bulbs that I can just swap over with the old ones?
    Regular Member Steve01's Avatar
    Aberdeenshire
    I fitted a set to mine, its easy enough, just remember to get the cancellers which were about an extra 15 quid as well or will show up an error and will not work properly.
    Plymouth
    I thought the ballast does that? It says in the link I shouldn't get the light fail warning.
    Aberdeenshire
    I did with mine and when I phoned them to say they didnt work properly I had to buy the cancellers as well. He said something about it might do that with some!!!
    Maybe some of the other guys will know better but i defo needed them and that was from HIDs Direct
    Aberdeenshire
    That was over a year ago i got them so maybe its different now and have been upgraded to sort the problem
    Sodding Typical on Sea
    If you simply order a set for the Vectra from wherever your choice is HID-direct HID4us etc etc the kit will inlude the cancellers needed to be sure they are working correctly.
    I would urge that you have the beam adjusted before fitting as they are all set very low so the throw of light is really disgraceful until reset, then the stock H7's will be working (badly) but at their best so when you fit the xenon's the difference will be even more noticeable.
  1. ALternative to thule!!!
    By sinless in forum General Motoring Chat
    Last Post: 2nd December 2012, 18:53
  2. What alternative have I got??
    By DaveW555 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 18:22
  3. HID alternative
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 14:00
  4. What's the alternative?
    By Xorro in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 15:34
