Thread: 1.9 cdti 150 Problem.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default 1.9 cdti 150 Problem.
    Has anyone come across this problem below?
    http://www.vectra-c.com/forum/showthread.php?t=123304
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    yes its more common than you think!, pump / cambelt gear is known to crack, slack in the cambelt is usually down to a failed water pump or tensioner!, common around 60k +.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Lets hope that's all it is.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by mally View Post
    If the pistons have hit the valves you maybe lucky as the 150 'should' just pop the cam followers!, & I'll repeat Should!, . Idon't think there's been much or any feedback from people regarding this as actual fact but someone may enlighten us no doubt.
    Engine : 1.9 CDTi
    Mine had the water pump seize and the pistons hit the valves.
    All it did was pop off 4 cam followers.
    Followers replaced and new water pump/cambelt kit etc and all was fine (All before I bought it with receipts to show work done)
  1. Cdti 120 problem
    By Vidar in forum Engine & Drivetrain
    Last Post: 26th December 2012, 00:25
  2. Problem With My CDTi
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 09:30
  3. 1.9 CDTI problem
    By chrish in forum Engine & Drivetrain
    Last Post: 26th September 2008, 10:17
  4. 1.9 CDTI 150 BHP problem
    By sumpyboy in forum Engine & Drivetrain
    Last Post: 18th July 2007, 21:31
  5. CDTi MPG? do i have a problem?
    By Andy in forum Engine & Drivetrain
    Last Post: 9th November 2005, 17:49
