Thread: Heater problem, help please
    Regular Member spandy234's Avatar
    Oct 2010
    milton keynes (bucks)
    Vehicle : Vectra C facelift
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    Default Heater problem, help please
    Hi was looking for some help , my heater in my vectra c is playing up you can have it on full blast or not at all ,highly annoying as my kids are freezin their little butts off in this weather any ideas what it could be ?
    on setting 1,2,3 it does not come on all
    is this a common vectra thingy ?
    Thanks alot
    Regular Member Steve01's Avatar
    Aberdeenshire
    Its the resistor mate. In beside the heater blower behind the glove box. Not a major job to change but bit fiddly! It will be because the drain is blocked under the plastic panel where the wipers are and water is coming in. Footwell probably wet also? Make sure change pollen filter at same as it will probably be soaked too. Here is the link, not sure but reckon there should be a how2 on here
    http://www.vectra-c.com/forum/showth...t=21620&page=3
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    there is a cheaper fix than that you can just change the thermal fuse its 79p from maplin RS23A
    Oct 2010
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    thanks guys will look in to this ,need to get it sorted asap .i looked online in maplins couldnt see that product code ,but i will visit the store and order from the catalogue .
    Aug 2010
    Luton
    Quote Originally Posted by spandy234 View Post
    think it might be RSA23A sorry about that
    Oct 2010
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    went to maplins and bought this ... now where do i put the poxy thing . no problem taking the glovebox out .
    Aug 2010
    Leeds
    After i saw the picture of the resistor pack i was thinking the same do you know what resistence that is and cost?
    Oct 2010
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    Found it heres the link to the answer i was looking for http://www.vectra-c.com/forum/showth...t=21620&page=7 thanks Vman
    Oct 2010
    Engine : 2.2 Direct
    Year : 06/56
    Mileage : 79k
    Quote Originally Posted by Bigtee View Post
    i got the thermal fuse from mapins 69p 240 looks easy enough fix im going to have a go will post the results ..
    Aug 2010
    Luton
    all you do is solder it on where the old one is remove glove box low right looking at it you push it forward and it comes off slots and remove
  1. Heater problem help
    By squeeze76 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 10:35
  2. Heater problem
    By kirstylt in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 20:16
  3. Another Heater Problem...
    By MMansfield in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2012, 22:57
  4. heater problem
    By rickeys16v in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2010, 02:34
  5. heater problem
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 00:00
