Results 1 to 10 of 21
Thread: Vectra c heater prob only blowing warm help
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Default Vectra c heater prob only blowing warm help
    Could anyone help me with my heaters in the car they all work fine 1,2,3,4, but they blow quit warm on 1 but when i turn them up to say number 2 or 3 they seem to cool down im frezzing ive change the thermo stat, both pipes to heater matrix are hot i have no over heating so cant be the water pump im realy stuck with this problem and its getting to cold to even put the kids it the car
    realy dont want to take it the vauxhall dealer the cost will be stuiped
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Remove header tank top, take 1 pipe to the heater matrix of (the bottom 1 would be best) and run the engine for a short time to bleed the system
    if air comes out then it needed bleeding
    when the pipe has water coming out push it back on
    top up the system put header tank top back on run the car up to temperature
    hope that helps
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Have you checked that the blower is clear of leaves? Remove pollen filter, change if dirty and see if you have a load of leaves stopping the air flow to the fan. I may be wrong but I think the Vectra cooling system is of the self bleeding type. Does your temperature gauge show a good temp?
    SHEFFIELD
    Yes i have cleaned the polon filter and stuff and pulled one of the pipes off the heater matrix and flushed it through and bleed the system as well still no joy
    Jul 2006
    TENTERDEN KENT
    What temperature does the gauge indicate when the engine is warmed up?
    SHEFFIELD
    The temp gets to about just above the 80 to 90 mark which i think is just below half if i put the heaters up on say number 3 the temp still stays the same i have put a new thrm stat in and its still not worked
    Jul 2006
    TENTERDEN KENT
    Have you checked the flap operating motors in the system? To do this turn the ignition on but do not start the engine, turn the left hand heater control to the various settings and you should be able to hear the motors operating the air control flaps. If you cannot hear the motors working this could be part of your problem.
    SHEFFIELD
    Yes ive tryed that i think its the one under the glove box its got like a red arm on it and when i turn it to hot and cold it moves up and down but ive just been out in the car and checked both the heater matrix pipes that goes through the bulk head and they are only warm are they supose to be only warm or are they supose to be red hot
    Jul 2006
    TENTERDEN KENT
    The control I mean is the LH one that controls where the hot air is sent to, it has symbols in it showing the air outputs. When the engine is at running temperture the two pipes should be too hot to hold. If they are not it would point to either a part blocked matrix or one or both of the pipes collapsed internaly. To check the pipes disconnect both from the matrix and connect them together with a piece of pipe (copper central heating pips or similar) and run the engine, if the pipes then get very hot the matrix is blocked. Hope this helps.
    SHEFFIELD
    Thank u carpet i will give that a go both pipes today was only warm and i could put my hands on them and that was after i had drove about 10miles
  1. Air con blowing out warm air
    By Baggers 2.0 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th August 2012, 17:26
  2. blowing warm not hot
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2011, 20:47
  3. Replies: 1
    Last Post: 28th September 2011, 21:57
  4. blowing look warm air
    Last Post: 24th December 2010, 16:07
  5. heater blowing warm
    Last Post: 3rd December 2010, 17:09
vectra c heater blowing cold
vectra c heater not getting hot
vectra c heater not very hot
Vauxhall vectra diesel heater does not blow hot
vectra heater giving hot air when off
vauxhall vectra heater not blowing hot
vauxhall vectra c heater stuck on hot
vectra c blows warm
vectra c climate control blowing warm air
vauxhall vectra heating blowing cold
vectra c heater not hot
Facebook
vectra c warm air
vectra heater not getting hot
not getting proper heating from my vectra c
vectra c heater blows cold warm only when driving
my heater doesntblow much hot air vectra c 3.2 Gsi 2002
Hester in my vecyra not very jot
vectra c heater blowing warm
vectra c heaters not very hot when driving
Vectra c heater only blowing warm
vauxhall vectra c heater just blowing hot
temperature vectra c will start blowing warm air soon after starting
vectra c heaters dont get hot unless revving
