Results 1 to 10 of 20
Thread: My speedo clocks keep stopin work vectra c help anyone
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Default My speedo clocks keep stopin work vectra c help anyone
    Hi every one im new to this site and only just started useing it so can some one help my speedo,fuel rev keeps stopin working does,nt do it all the time only in a morning when its cold after ive drove the car abit it stops doing it,, when it does i just turn the car off and back on again and all is fine then few min,s later it all goes off again, once i get to work in a morning and the car is left all day while i work then drive home it does,nt do it realy puzzled with it
    ive looked to remove the clocks but havent got a clue how to or if some one has some pics on how to do it hope some one can help or tell me what to do to solve it realy getting on my t**ts now lol.......
    SCOTLAND
    i had a similar problem on my old corsa c only the car would not start after i'd turned it off. My guess is its probably either a loose connection behind the dials or possibly a control module.
    Devon
    79 Post(s)
    Vehicle : insignia
    Trim : irmscher
    There's a good chance it could be your ABS plug under bonnet removing this and making sure it's clean has cured a few members problems regarding speedo faults esp on DTI engines .
    Irmscher Insignia CDTI 130
    SHEFFIELD
    Thanks guys ,,,the clocks just all stop working hand break light comes on abs light fuel stops temp stops as well turn the car of back on works again i will try the abs under the hood where abouts is it
    SHEFFIELD
    Just letting u know as well it only the 1.8 ls model
    Devon
    79 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Try taking out fuse 17 passenger side of dash and make sure its clean and seated properly then look under bonnet just to the back of battery there's a big black plug,unplug then and make sure its clean and then make sure its plugged in correctly
    SHEFFIELD
    Hi mac ive unpluged it give it a clean so ill see what happens see if it does it again when i go out sortly ive also cheecked fuse 17 on the passange side seems ok my,n is a 15amp fuse i hope this is the right amp fuse if it is then it looks fine to me thanks gays on the help u have given me nice that people do try to help u on here for a change
    thank u ill keep u posted if it does it again after a good clean now and a check on the fuse
    SHEFFIELD
    Hi ive done what u have said to do and ive just been out and its still doing it mmmmmm :~(
    SHEFFIELD
    Sorry bigmac i just noticed today when the clocks went off the side lights cam on turned the car off and back on again clocks worked and side lights went off i give up on this
    realy thinkin off getting rid
    cambs
    same happend to mine last year.
    its the cim thats the problem and will need to be replaced.
  1. speedo clocks
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 00:25
  2. HELP! speedo clocks wont work?!
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2009, 13:24
  3. speedo clocks on a 1.8 ls
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 20:45
  4. speedo clocks
    By pipcurry in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2007, 23:05
