Thread: 235/45 R17 Tyres!!!
    Scunthorpe
    Default 235/45 R17 Tyres!!!
    After looking at a tyre size calculator i have discovered that the 235/45 R17 gives a closer speed difference to the standard 215/50 R17 that the 225/45 R17 does.
    Is anyone running on these and will these fit on the standard Pre-Face SRi alloys.
    If so anyone had any problems with them been to wide, rubbing etc???
    Cheers Tom
    Sodding Typical on Sea
    I ran them on a 7 x 17 rim on my Saab and in truth when measured the amount of rubber on the road is about 4>5mm wider only due to the clamping effect if you fitted the same tyre to an 8 x 17 rim it would be about 27mm wider than a 215/50 17 on a 7 x 17 rim.
    Scunthorpe
    Cheers for that!
    Dont suppose you know how wide the Pre-Face SRi alloys are. Are they 7 inch or 7.5 inch!!!
    Vauxhall alloys are all 7J x 17 oem 8x18 and 8 x 19 IIRC
  3. More tyres....!
