Thread: Tie rod replace
    Regular Member blackveccyC's Avatar
    Dumfries
    Default Tie rod replace
    Hi lads n lassies.
    Today i was planning on changing both tie/track rods, as the driver side wheel has wobble and the tyres are bald on one side. All was going well - wheel off track rod off gator off no problems, However when i got to the tie rod this thing is not for moving, adjustables no chance, tried hitting the ball joint a little to loosen - still the same. Phoned around for a removal tool phoned a garage round the corner and they kindly leant me a wrack wrench. still not for budging i think the person who put it on welded it lol. Or at least thats what it feels like.
    So had no choice but to put it back together with new track rod and old tie rod, what can i do? I didn't want garage to change them as i need to save where i can. any suggestions more than welcome.
    Aug 2010
    herts
    Dumfries
    yeah the one i borrowed is similar in design to that but a much cheaper version, that one looks more solid and probably have more sucess with that one. lot of money to gamble with though.
    Aug 2010
    herts
    chance you take!!!!
    Dumfries
    your right mate, think i have to still cheaper than taking it to a garage i suppose.
    Dumfries
    come to think of it, when you use this do you go the opposite way from what you would normally do. ie if i was slacking a nut id go anti clockwise as normal but if slacking the tie rod with this would i go clockwise to slacken it? just a thought.
    Aug 2010
    herts
    anti clockwise mate it works like a ratchet.
    Dumfries
    Aye the driver side one came out no problem luckily this is the problem one. So will make do with the old one still on passenger side. Will get that one into a garage after Xmas when more funds available. Alls left to do is put it together and off to get wheels and alignment. Cheers lads.
    Sep 2010
    worcester
    heat............ blow torch oxy/acetlene heat it up as much as possible spray with wd 40 then reheat do it until it gives.... just done omega one same problem it gave in eventually
  1. Cim Replace
    By Markov in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 22:58
  2. Can i rip out and replace?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 11:17
  3. Replace 215/55/16 with 195/50/16
    By battsman in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 16:18
  4. Replace my TID with a dvd?
    By ryantcb in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 15:46
  5. Need to replace all 4 springs - HELP!
    By Screechxl in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2009, 18:46
vectra c tie rod replace
