Thread: 'Safe Guard' message (Codes inc)
    Engine : 1.9 CDTi
    Default 'Safe Guard' message (Codes inc)
    Since buying my Signum I have always had the 'Safe Guard' message.
    I have read the codes and this is what I have got:
    Total number of fault codes: 3
    B2955 - Anti Theft Warning System Sensor Datalink Circuit Low Voltage or Circuit Open
    (06) - Present
    B2955 - Anti Theft Warning System Sensor Datalink no Communication
    (0F) - Present
    B3916 - Powersounder Malfunction
    (39) - Not present
    I have replaced the ultrasonics with a working one from a member on here and the Power sounder one can be cleared but comes back now and again.
    How do you replace the power sounder? Do they need coding to the car if I get a second hand one?
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Try setting your alarm off...
    Sounds to me like someone has tried the "make your alarm louder" trick
    This entails just unplugging the power sounder in the boot / load area, so that the car uses the Horn(s) instead.
    If your sounder is present and fitted, try checking the multitude of fuses in the rear fuse box.
    It may also be that the power sounder was unplugged due to a flat sounder battery - this would result in the alarm going off randomly... usually at three in the morning.
    So the options are: -
    1) Sounder Unplugged
    2) Blown / missing fuse
    3) A final thought - BCM or REC or DIS have not been programmed fully to recognise the alarm as "present" in the variance coding
    Engine : 1.9 CDTi
    Any idea what fuse to check?
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Here you go... from the Vectra owners manual
    Engine : 1.9 CDTi
    Ah thats great.
    I take it the Signum is the same (As thats what I have)
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Yep -should be...
    Signum is virtually an upgraded Vectra-C estate.
    Uses the same floor plan etc.
    Engine : 1.9 CDTi
    Thats great,
    Thanks for the help.
    Jun 2007
    Glasgow
    I too have been suffering from random alarm activations - the codes are the same as above -
    B2955-06 - Anti Theft Warning System Sensor Datalink Circuit Low Voltage or Circuit Open
    B2955-0F - Anti Theft Warning System Sensor Datalink no Communication
    B3916-0F - No communication with alarm siren.
    So is it the Ultrasonic module that is goosed? I did try the car with the Ultrasonics switched off from the instrument panel - I guess the unit is probably still powered up though.
    If the unit is goosed, is it easy to change and rough cost?
    Lindsay
    Engine : 1.9 CDTi
    Fitted a known working set and mine still has the warning.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    I have the same problem today. Change fuse 21 and 23 and everything its ok. Is your alarm ok now?
  1. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  2. Power Tail Gate & Safe Guard
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2012, 14:49
  3. Cars says check safe guard
    By Sri-chris in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2011, 23:35
  4. Safe guard
    By larrysSRI in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 10:31
  5. Safe Guard
    By Marc Hutton in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2008, 17:45
https:www.vectra-c.comforumshowthread.php123387-Safe-Guard-message-(Codes-inc)page2
