Thread: Lights flashing, won't turn over.
    Regular Member blackveccyC's Avatar
    Dumfries
    Default Lights flashing, won't turn over.
    Hi folks just changed the tie rod on passenger side and went to turn car around but car won't start, When i turn ignition all the lights in the dash flash can hear a clicking but there is no turning over of the engine. Have tried bump start, same. have just disconected minus from battery to see if that helps.
    any ideas what this could be, never had a problem starting with it before today, had it for 6 months..
    Petrol X18xe. Thanks Guys, urgently need this sorted.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Sounds like the starter is sticking, or the battery has not enough charge to turn it over. Is the clicking a fast tick tick tick sound?
    Dumfries
    aye its quite a fast tick tick tick, got the battery off the car now as the minus lead off for 10 mins didn't work. See what happens after its fully charged, hope the battery isn't ****ed.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    m8 id say hope battery ****ed not starter as battery cheaper......just me tho
    Dumfries
    well when you put it that way lol. Fingers crossed, battery was below 12v now its increasing about 12.91 does this sound about right?
    Sep 2010
    in a box
    .........dono lol but yer hope battery not starter diffrence is bout £100 so ill vote battery if you got jumpleads try them if it dont start then it starter
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Sounds like battery to me. The clicking noise you will be hearing if the solenoid for the starter motor opening and closing because there is not enough power to turn the starter over. Its amazing how a few sub zero mornings can knock ten bells out of a dodgy battery. When you get it started run the multi meter over the battery, if your getting 13.5-14.4v you can rule out the alternator.
    Sep 2010
    in a box
    it could be sticking m8 and it will just go click click
    Dumfries
    Panic over lads (untill tommorrow morning at least) gave it a good charge, stuck it back on the car started first time, thankfully. Will run the multimeter over it tommorrow if/when it starts and see how we get on. Man its amazing how much it drains the life out you when you have no car even for a few hours lol.
  1. flashing brake lights????
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2012, 10:58
  2. Flashing/Flickering HID Fog-lights
    By Damo77 in forum Styling
    Last Post: 24th March 2011, 11:50
  3. i'm seeing flashing lights!!
    By jmcmil15 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2010, 17:47
  4. wahoo flashing lights
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 18:11
  5. Flashing brake lights
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 20:51
vauxhall vectra c battery charged but wont turn over
